Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Car wouldn't start--starter replaced--now wiring burnt out
Old Oct 23, 2019 | 06:33 AM
tsb8m's Avatar
Default Car wouldn't start--starter replaced--now wiring burnt out
Old Oct 23, 2019 | 02:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Car wouldn't start--starter replaced--now wiring burnt out
It is unlikely that the starter wire will cause an engine fire or something catastrophic... odds are that you will simply get stranded when the car fails to start with the key. Charge harness issues have been common in "K" series applications since their inception here in the US in 2002, so replacing this part may likely solve your issue for now... and likely work for years to come. As for it causing a failure... maybe... but it is likely that the tech stopped diagnosing when he discovered the bad starter AND installed a sub-standard starter that failed quickly and doesn't want to do the warranty labor for free.
sugafree
Sep 21, 2015 03:05 PM
Uljima
Nov 10, 2014 04:46 PM
baastard
May 25, 2006 07:52 PM
thevtecnician
May 16, 2003 10:42 AM
