Just picked up a 2000 Civic EX Coupe! Need Pointers For This Project!
Old Oct 22, 2019 | 08:34 PM
dylan97's Avatar
Default Just picked up a 2000 Civic EX Coupe! Need Pointers For This Project!
What's up, guys. I just picked up a 2000 Civic EX and decided I would join this forum. I picked it up for free from a family friend. It runs and drives, but has one issue, it has the idle surge from 1k to 2k when it's warmed up. If I unplug the TPS it's fine but if not then it surges. I know this has been asked a thousand times, I've googled and searched but maybe not hard enough. I put in a brand new IACV so I don't think that's it. I wanna look for vacuum leaks next but I don't really understand how. If anyone can give me some pointers on where to start with that, that would be great. And if anyone wants to help me make it pretty with some mods, feel free to post your favorites or ones that you think would be good! I need ideas. Thank you!
-Dylan
Old Oct 25, 2019 | 05:27 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Just picked up a 2000 Civic EX Coupe! Need Pointers For This Project!
approval bump
Old Oct 26, 2019 | 05:15 PM
xprest1ge's Avatar
I'm having the same issue, definitely search this forum for 'IACV' and you'll get a lot of results. I've read spraying carb cleaner around the intake hoses might show you if you have a leak, as it'll suck it up and you'll notice by the sound of the engine. You can also spray some warm soapy water around some of the hoses and check for bubbles.
I think I also read you could have air in the coolant, so maybe bleed it. Again, I've read at least 8-10 threads on the forum around IACV so I suggest you read the replies in those threads.
Old Oct 26, 2019 | 08:46 PM
Freedo_Civegra's Avatar
The carburetor cleaner trick is good, but not the soapy water. Engine vacuum will suck it in, not blow bubbles.
OP, have you checked codes?
Old Oct 26, 2019 | 11:56 PM
dylan97's Avatar
i checked codes yea, one for a knock sensor and another was for the PCM detecting a problem with the IAC valve. but the valve i got is brand new :/ could the knock sensor be doing it ? smells like it’s running hella rich too
P0509
P0505
P0325
Old Oct 27, 2019 | 08:41 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Check coolant level
Old Oct 27, 2019 | 05:39 PM
dylan97's Avatar
Originally Posted by Caoboy
Check coolant level
Just looked, it took about a quart of coolant until it hit the max line. still surges. Also i see you're from the central valley, me too. what area code? im 209
Old Oct 29, 2019 | 09:09 AM
tony_2018's Avatar
Fish Twig
bleed the coolant. Just don't fill it up and be done with it,...
dazasero
Mar 18, 2017 09:55 PM
bpcarnut
Dec 9, 2012 07:48 PM
nafreak
Jul 21, 2010 03:06 PM
h22apwrdcivic
Dec 22, 2009 03:01 PM
