Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Honda Civic Won't Start No Crank
Old Oct 22, 2019 | 05:34 PM
tanked_honda's Avatar
Default 2005 Honda Civic Won't Start No Crank
Hi, have a 2005 Honda Civic LX auto
I thought it was the starter, replaced it but still wont crank. (Doh)
Anyways I turn the key and it clicks once, dash lights are on, some go off when I turn the key, battery is good.
Getting frustrated.
Old Oct 23, 2019 | 04:58 AM
NDNV's Avatar
Default Re: 2005 Honda Civic Won't Start No Crank
Check the battery, battery connections, grounds, alternator and loose alternator mounting bolts that can give a poor ground and other electrical gremlins.
Any codes stored with a Check Engine Light on?
Old Oct 23, 2019 | 07:41 AM
any idea where all the grounds are on the body and engine, do I need to jack up the car?
Old Oct 24, 2019 | 04:30 AM
kaivorth's Avatar
One should be under your fuse box on the left side of the engine bay.
One right in front of you in the middle front of the engine bay.
Look up the big 3 ground upgrade for our vehicles and you should see them all
Old Oct 24, 2019 | 01:10 PM
ahh what a good idea thanks, here I was typing into google, 2005 honda civic grounds, getting horrible results
Old Oct 27, 2019 | 09:32 PM
Im going to give my car to my mechanic. After replacing the starter and IGN fuse, even though I have a stronger "click" I cant afford time wasted on this thing. Damn, Hondas are not that reliable, my old Pontiac Sunfire ran better. Only thing is the civic has better MPGs.
Hopefully its a ground problem or something.
Old Oct 28, 2019 | 05:14 PM
hondandy's Avatar
Hondas are not that reliable, my old Pontiac Sunfire ran better..
The only way you will get something more reliable is a toyota possibly. But personally I can't stand driving a tercel or corolla compared to many Hondas I've driven. I do rock an older toyota truck however. I agree the 7th gen is a little less reliable than previous civics and people seem to have issues with high mileage ones with questionable maintenance records. I haven't had any issues except with struts and locks, but then I haven't hit 200k yet. I think the 5/6 gen is Hondas civic sweet spot. Also it seems people drive the cars like they are in fast and the furious but figure they need zero maintenance since it's a Honda and will go 350k no matter what you do or don't do.
Old Oct 28, 2019 | 05:16 PM
hondandy's Avatar
Try using jumper cables hooked to another running car just to see if it turns over. You could have gotten a bad new part, it's been know to happen.
Old Nov 2, 2019 | 03:00 PM
Default PROBLEM SOLVED
Well i paid 90$ to have it towed to my mechanic and he figured out it was a bad aftermarket positive terminal battery clamp! He took it apart and cleaned it and it fires up strong now!
Cost me a case of coors for the repair.
All in all it was:
140 for initial tow
170 for starter
4 for suspicious looking ign fuse (was brown and melty)
About 2 hours of my time
90 for another tow
38 for a box of coors
342$
Im not worried if i replaced a good starter, it was 14 years old anyways and its a oem rebuild now.
Freeme2018
Jan 22, 2018 09:23 AM
nickkxo
Jan 4, 2018 08:09 PM
jmcnroe
Honda Civic (2006 - 2015)
Jul 30, 2016 11:45 AM
