Need some help with rear suspension setup
Old Oct 18, 2019 | 07:14 AM
S1lv3rW1z4rd's Avatar
Icon5 Need some help with rear suspension setup
Hi,
I'm stuck with a question regarding the rear end on a VTEC CRX.
I'm building again from scratch and the lower outer bushing doesn't line up where the trailing arm sits.
My question is this normal or not ?
Might be the bushing in the upper control arm is a bit off.
If the line up is normal how do I proceed with attaching the lower arm to the trailing arm ?
Jack underneed the shock/lower arm to get it up a bit ?
I can pull the trailing arm down as well but it seems to stress on the bushing that connects the upper arm to the body.
I don't want to ruin the new bushing on the upper arm hence my questions.
Here are some pics;
Old Oct 18, 2019 | 07:59 PM
Tyson's Avatar
Default Re: Need some help with rear suspension setup
It should all fit in place much nicer after you jack up the suspension and the weight of the corner is on the suspension, right at the point the car lifts from the jackstand.
This is how you're supposed to do it according to the shop manual. It's also good for keeping your bushings in good shape, and you don't rip them.
Old Oct 23, 2019 | 10:30 AM
Hi Tyson,
Ok thanks, I'll give it a go later this week with the help of my jack.
My shop manual mentions nothing about the rear trailing arm removal/assembly.
It looks like an OEM manual (681 pages), are you using something else ?
Old Oct 23, 2019 | 10:45 AM
Tyson's Avatar
Old Oct 23, 2019 | 10:58 AM
Ok right I missed that
Old Oct 23, 2019 | 11:28 AM
JDMMike78's Avatar
Your car looks super clean, do you have a build thread started on this?
Old Oct 23, 2019 | 11:36 AM
No not yet, but I'll get one started
S1lv3rW1z4rd
Oct 17, 2019 11:27 AM
ashtonallen
28
Nov 10, 2014 06:56 PM
6ghatch
22
Jan 29, 2006 10:15 PM
Chase Taylor
Apr 7, 2004 04:06 PM
