CALIFORNIA: Y8 in 95 civic bar’d able?
Yes...However you will have to make it OBD2 compliant. My cousin had an OBD2 LS swap in his '95 Civic EJ coupe and he had to do the same thing when he relocated from NC to CA.
hm, that would mean you'll need the proper harness so you won't have to worry about running wires all over the place. obd1 harness won't have the pins or wires for obd2.
It is a direct replacement engine, no bar necessary.
NVTurbo the B18 never came in a Civic in the US that's why he had to BAR it. Come on, this is basic 2006 stuff guys. Stop spreading bad information.
https://www.bar.ca.gov/Industry/Engi...uidelines.aspx
When people start mixing parts from all the engines together is where you're going to get in trouble. Just use the long block and your cars stock intake manifold, exhaust, or approved CARB exempt parts until you know what you can get away with.
The Y8 came in a US Civic period. The only time year matters is when you try to use an engine that is older than the chassis it's going into (no obd1 engines in obd2 chassis, no obd0 engines in obd1 chassis). I haven't compared the engine labels to know if all years are in the same engine family but it's really lot a lot less complicated than you all make it seem.
Its even worse when people who don't live in the state, know the laws, or actually know what they're talking about add in their 2 cents.
Rossco951
Sep 11, 2016 01:11 PM
myflyintegra
12
Jun 21, 2015 12:08 AM
ScubaStevo80
Sep 23, 2005 04:08 PM
