How much horsepower will a d15b7/y8 mini-me produce
I am doin a mini me in my 95 civic. with my b7 blcok and a y8 head. I wanna kno how much horsepower it will make jus stock. If anyone knows please hit me up with some info. I jus wanna kno. Thanks
Re: How much horsepower will a d15b7/y8 mini-me produce
I have saw 2 of those done and with only simple bolts ons. like cold air and exhaust 1 of them was 146 hp and the other was 143 but I have heard of more and less. This is just all I have saw.
you should expect like 125-130 BHP on a stock B7/Y8 mini-me. With intake and exhaust, maybe 135-140 BHP at the crank.
hi guys!
I`m sorry! Can you tell me please
1.what do I need for swap d15b7 with Y8 head?
2. wich head will be better Z6 or Y8?
or may be somebody gives me link to read!
thanks in advance!!
thanks in advance!!
http://lmgtfy.com/?q=mini+me+swap
in the future, make your own thread after searching
google it bro... or how bout i do it for you...
ok! everything is clear tnx
My b7/z6 with an intake and exhaust wanted 5-10% more fuel in the WOT cells than a stock z6. Assuming that's somewhat proportional to torque, that's ~135 bhp. However, OEM engines run conservatively at WOT, so it's probably a little higher than that.
A b7/y8 will make slightly more power than that due to the higher compression.
the head is just a direct bolt on just make sure you remove the oil jet out of the block its on the intake manifold side use the vtec head bolts if i remember correctly they are a little longer. as for the head the z6 or y8 head are pretty much the same. The y8 head and manifold flow a little better that why it makes like 2 more horse power lol get your self an EX/SI tranz they are worth their weight in gold. and if you got some time get your self some D16a6 pistions to bump your compression and then you will be putting down some decent numbers.
my 94 eg8 has b7/y8 mini me , it ran almost & was way quicker than a stock b7 non-vtec , only down fall is I'm running a auto til I can find a 5speed swap.. stock b7 only has 102hp
superhatchbackbros
09-30-2010 05:59 AM
