Cel issues
Okay, so i felt like the car was running rich, and i was pretty sure it was the oxygen sensor but I wasn't throwing any Chick engine light so I decided to jump the post to see the light code and it's pulling a 41 which is the oxygen sensor heater, so it was the o2 sensor. My question is, if i can pull that 41 code, why wasnt my cel on?
So the question still is, why didnt the code turn on the cel?
Also, i had a bad misfire from a bad spark plug, and it too didnt throw a cel
Remove and replace the ECU and Back Up fuses under hood, disconnect the ECU and plug it back in, or disconnect the negative terminal on the battery and reconnect. Regardless of how you choose, wait at least 30 seconds in between removal and re-install.
