Window issuee
Old Oct 3, 2019 | 08:57 AM
Honda76's Avatar
Default Window issuee
So I finally had time to work on the Honda I bought. So I installed the manual window regulator and new runner. I lubed the crap out of it with silicone but Everytime I roll the window it is like it's only rolling the left side which throws it off track. I have been two days trying to figure this out. BTW this is the driver's side.
Old Oct 3, 2019 | 09:23 AM
tony_2018's Avatar
Fish Twig
Default Re: Window issuee
It's either catching on something that's dragging
Old Oct 3, 2019 | 09:39 AM
Honda76's Avatar
I think the wheel on the bottom guide is not sliding right. Just took it apart so I can lube it up and pray. Lol.
Old Oct 3, 2019 | 11:00 AM
Honda76's Avatar
So still no luck. I have tried everything I can think of and even swapped the track. I know it's rolling but it's like the ride side has no support and just flops down.
Old Oct 3, 2019 | 12:08 PM
tony_2018's Avatar
Fish Twig
refresh my memory, but the honda you have uses a cable driven manual crank? Is this a new crank or did you grab this off of a honda in the yard? You sure you also bolted the glass to the manual window regulator?
Old Oct 3, 2019 | 12:58 PM
Honda76's Avatar
MILLION PARTS Manual Window Regulator Front Left Driver Side fit for Honda Civic 1996 1997 1998 1999 2000
Amazon Amazon
This is the regulator. All bolt are in and I have taken the thing apart and put it back together. It was bought brand new. I didn't buy it because it came with the car but it was still in the box sealed in a bag from amazing. I will post a picture of the door and rails when I get home and maybe I missed something or something is out of wack.
Old Oct 3, 2019 | 01:16 PM
tony_2018's Avatar
Fish Twig
might be a seal thats grabbing the glass or the glass isn't on the track properly.
tony_2018's Avatar
Fish Twig
also wanna make sure all the bolts are in place.
Old Oct 4, 2019 | 02:14 AM
Honda76's Avatar
I think it might be a bad regulator even though it's new. I tried it without the deal and it does the same thing.
Old Oct 4, 2019 | 06:31 AM
Honda76's Avatar
This is where I'm at now. It's like the window isn't big enough as it just flops down on the right. Why is it I can year apart a engine and rebuild it but a window has me stuck...lol
Old Oct 4, 2019 | 04:29 PM
timbobbey's Avatar
it does sound like the window regulator is bent maybe. I would take it out just to check and see if it is bent or binding on something.
Old Oct 4, 2019 | 05:48 PM
Honda76's Avatar
I will take it out and post some pics. I didn't notice anything bent but I could be wrong. This is my first window job ever. Never had a issue in all my other cars with windows.
Old Oct 5, 2019 | 06:23 AM
tony_2018's Avatar
Fish Twig
loosen the bolts holding the glass, push the glass all the way up and hold it with tape, see if you can rotate the crank up and down.
Old Oct 5, 2019 | 07:50 AM
Honda76's Avatar
It goes up and down. Just right side falls down.
Old Oct 5, 2019 | 09:30 AM
tony_2018's Avatar
Fish Twig
take a pic of it, glass taped to the door in placed.
Old Oct 5, 2019 | 04:19 PM
Honda76's Avatar
Will try tommorow if I can. If not I will try and work on it Monday.
import-tooner
Mar 3, 2010 04:19 PM
strictly.business
15
Nov 28, 2006 11:20 AM
ev13lf
Jan 23, 2006 05:32 PM
