turbo B series part out (Turbosmart, Garrett, built head, built trans)
I know HT is an echelon above the shitty Facebook groups and craigslist/offer up garbage we have to deal with these days, but Im still gonna preface my ad with this: No trades, no atvs, no dirtbikes, no shells, no d series parts. Please, if youre poor leave me alone, thanks. Now, onto the go fast parts.
Parting out my civic drivetrain. Car made 365whp on pump gas on a stock port LS head. All the engine and transmission parts were purchased new and have about 1000 miles on them. Turbo parts have about 10-12k miles.
Ferrea Comp plus intake valves & 6000 exhaust valves...... $200
Complete b18b head with BC cams, ST springs, Ferrea valves, new Mahle valve seals, etc plus oem distributor, ngk plug wires, speedfactory billet cam seal, intake mani, throttle body, fuel rail, sensors, etc....
$700 WITH CAMS OR $560 WITHOUT
Manley h-beam rods with bolts, torqued once.... $240
Southbay 1000cc injectors, only saw 93 octane fuel, the tops have been milled to direct fit b series fuel rail and the bottoms have b series adaptors, weird, but it works.... SOLD
Neptune RTP ecu... $340
ARP headstuds $80
TURBO PARTS:
Intercooler (400-450hp) with 2.5 inch piping and IAT sensor bung welded on charge pipe, Turbosmart bov flange, all couplers and t bolts... SOLD
Turbosmart Ultragate 38 with brand new diaphragm and various springs.... SOLD
Cast iron manifold with high temp black paint... SOLD
Garrett 54mm turbo (STC Hunter) ball bearing, wrinkle black high temp coating, billet wheel, .63 A/R, ported turbine housing, some shaft play.... SOLD
Turbosmart VPort bov....SOLD
Bumper exit downpipe, 100% stainless steel, tig welded, 2.5 to 3.5 inch, 2 vband connections for easy on and off... SOLD
Wastegate dumptube, stainless steel, 2 bolt 38mm... SOLD
TRANSMISSION PARTS:
Built s80/LS transmission
Liberty faceplated 1st/2nd
Synchrotech hardened 3rd/4th hub and slider, with Pro Series carbon synchros
MFactory LSD, Speedfactory springs
All new OEM bearings and ring gear bolts (got $440 in receipts from the dealer)
New oem 3/4 shift fork
SOLD
Action stage 3 clutch SOLD
Stock flywheel SOLD
Integra shift linkage with HardRace bushings, all new oem hardware, dogbone extension SOLD
Stock axles with intermediate shaft $100
OBD2 integra harness SOLD
Mounts SOLD
I have other stuff too, hit me up.
Re: turbo B series part out (Turbosmart, Garrett, built head, built trans)
Originally Posted by Nathan937
Do you happen to have the size of the intercooler? I’m interested in that and the piping kit. I wonder what shipping would run on that.
Overall size is 29x8x2.5, the core dimensions are 22x7.5x2.5. I want to say it was around $20-25 when i bought it. I can work with you on price depending on shipping cost.
Originally Posted by k20z1ej1
Trans sold
block and crank sold
bov sold
map sensor sold
shift linkage sold
mounts sold
harness sold
flywheel sold
clutch sold
map sensor sold
wastegate pending
Thanks guys!
need you to follow those guidelines in yellow, boss... be nice and delete/strikeout what you've sold, and PM any personal/mobile phone numbers to those that are interested. you're doing well, but please clean this up.
24 hours & counting..
my first picture has a handwritten sign in it with the date, my username and hondatech.com, that isnt sufficient?
