Built d16 for 1 million horsepower. what transmission should I use?
Old Sep 30, 2019 | 07:47 PM
bldzrr's Avatar
Default Built d16 for 1 million horsepower. what transmission should I use?
I'm going with a fully built sleeved turbo d16 for around 400whp. Based on gear ratios, I'm trying to find out what transmission is best? I've heard I want the y8 tranny but I'm just looking for more info and opinions. Thanks
Old Oct 2, 2019 | 07:47 AM
NVturbo's Avatar
O.G. triple O.G.
Default re: Built d16 for 1 million horsepower. what transmission should I use?
Y8 tranny with new internals....
Old Oct 2, 2019 | 09:31 AM
Txdragon's Avatar
I've been using the DX transmission. Has served me well. Of course, I have NO clue how exactly to tell them all apart, DX vs Si, etc.. They all have the same look and tags, just a slightly different gearing. It revs fairly quick, maybe it's the Si trans? I dunno.. It was attached to the original B7 engine when I got the car and has been through 3 turbo setups.. The B7 setup, and 2 on a Z6. I've beat the **** out of that transmission and it's serving me well.. **shrug**
Old Oct 2, 2019 | 09:43 AM
maxwellmercer's Avatar
There's a casting next the the passenger axle seal. A000 is base model, B000 is ex/si. IIRC!
Old Oct 2, 2019 | 12:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
400 WHP is kind of that "either way" area... the shorter geared EX/Si trans may be a bit more difficult to drive because of the closer gearing, but it will feel very strong and pull hard when you have traction... and the DX trans will be better spacing leaving you in boost longer in each gear, but you will lose a bit of acceleration in each gear as well. My opinion is use the DX trans as Txdragon suggests.
Old Oct 4, 2019 | 08:41 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
It really depends on how broad or narrow your power band is, the y8 trans is still about as long as a hydro ls Tranny so its not like it super short geared either way.
Old Oct 4, 2019 | 09:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
It all depends on what you want to use the car for. Quarter mile? Half mile? Top speed record? Daily driver? Use this calculator to play with gear ratios to help you decide: https://www.zealautowerks.com/transcalc.php
The Y8/S40 transmission is desirable due to the steel shift forks. The Z6/S20 transmission has cast aluminum forks.
Old Oct 4, 2019 | 11:01 AM
Txdragon's Avatar
Damn... Really? They'd have been only marginally worse if they were made of glass.
joseincaliEJ8
Feb 15, 2011 05:32 PM
d17beast
Honda Civic (2001 - 2005)
17
Sep 28, 2009 06:44 AM
Ilovemyef9
Sep 7, 2007 07:04 AM
M.A.R.C.
Oct 18, 2003 12:09 PM
ZeroAccess
10
Jun 19, 2003 04:38 PM
