B20 swap help
Old Sep 30, 2019 | 09:41 AM
Dtx_mikey's Avatar
Default B20 swap help
Hey guys im new to all this. Chew me out or call me stupid or say i did not research but i cant find anything that answers my exact questions.
I have a 1995 acura integra. Recently cylinder number 4 has no compression. so im looking to swap a b20b high comp into my teg since its plug and play. Not to mention its cheap. I know i can use my manual ls trans and my p75 ecu to run the swap And my ls intake manifold but what aftermarket intake manifold could i use ? Are aftermarket b18b1 intake manifolds usuable on the b20b ? And what mounts will i need 3 hole mounts or 2 hole mounts ?
Id really appreciate some feedback and help
Thanks
- mike
Old Sep 30, 2019 | 11:25 AM
maxwellmercer's Avatar
Default Re: B20 swap help
You can use any intake manifold that is fitted for b18b/b20, simple as that. Do you have the 3 post mount in there now? Well good news, you can use the LS post mount on your b20 and use the existing factory mounts or buy aftermarket accordingly.
Old Sep 30, 2019 | 12:07 PM
MotorMouth93's Avatar
10 Year Member
The B20B motor is externally nearly identical to an B18B1 with the exception of a knock sensor on the high comp B20. Any intake manifold that will work on a B18B1 will work on the B20.
You use the same mounts from the B18B1 as well.
And yes, a P75 can run a B20 just fine, but without tuning it won't really feel any different to drive.
Old Sep 30, 2019 | 12:32 PM
tony_2018's Avatar
Fish Twig
PHK, remember to look for that.
Old Sep 30, 2019 | 12:41 PM
Dtx_mikey's Avatar
Thank you so much for your replies. Could you recommend some good after market mounts to use ? And recommend a good aftermarket intake manifold to go for ? like moderate price range ? And its going to get tuned eventually. Btw whats PHK ?
Old Sep 30, 2019 | 01:28 PM
tony_2018's Avatar
Fish Twig
hardrace, hasport, hasbeen.
Brawnz328
Mar 4, 2017 05:31 AM
ArickAndHisAccord
Jun 16, 2008 07:15 PM
eugene_fender
May 23, 2007 06:23 PM
NoLeftTurn
Mar 10, 2006 11:41 AM
zerovandez
Jul 7, 2005 07:51 PM
