No fuel to carburetor
Greetings folks,
I own a 1982 Accord lx. I am not getting any fuel to the carburetor. I just replaced the fuel pump with a new one, and still no luck. Would the fuel cutoff relay have anything to do with this? The relay looks fine, solder connections all look snug and secure. What other things may be causing my issue?
[QUOTE=MICHAEL MAY;52019149]Greetings folks,
I own a 1982 Accord lx. I am not getting any fuel to the carburetor. I just replaced the fuel pump with a new one, and still no luck. Would the fuel cutoff relay have anything to do with this? The relay looks fine, solder connections all look snug and secure. What other things may be causing my issue?[/QU
*if the pump is electric it should make a noise and did you check the filters(engine,tank ETC)as well as any kinks in the lines go through those first its cheaper except for the tank sock that's a little work and a little carburetor cleaner in the carb might help a little as well
musikpal
Mar 26, 2010 06:08 AM
