Converting to b-series A/C compressor
Wassup Honda-tech, I have a 99 civic with a b18c1 & I'm looking to use a em1 ac compressor & bracket since I can't locate a p54 bracket. I slapped on a p7j bracket & my sohc compressor fits but the torque mount doesjt with that bracket. The car currently has all the original d16y7 ac components. Does anyone know what I would need to change to make this work? I'm thinking the suction line & discharge line is the only thing that's different from the d-series but then again I dont know. Any help would be greatly appreciated. Thanks boyz...
Does the EM1 use a “b” compressor or “d”? If it uses a b, just compare hose/line part numbers to yours. I know I have an em1 evaporator on my 92 using 95 lines and d-series compressor with delsol vtec bracket, so some components have to interchangeable.
The p7j is to use the d-series compressor, if you want to use the em1 compressor you'll need the em1 bracket. I'd suggest looking at salvage yards and call to verify.
Mr. Dabolina
Jan 18, 2014 08:06 PM
1.8
12
Dec 18, 2004 06:36 PM
