Swapping a F20b into my manual 94 accord. Please help!!!
Old Sep 22, 2019 | 08:45 PM
94accordf20b's Avatar
Default Swapping a F20b into my manual 94 accord. Please help!!!
I purchased a F20b for 531$ with a 90 day warranty. It came with the engine wire harness and ecu. I pulled out my f22b1 from my accord and planning on reusing the f22b1 transmission until I can afford a better transmission. The motor mounts that were on the car originally were shot so I ordered new motor mounts. The axles are ok. My issue is the wire harness for the motor. I have read that I can reuse the f22b1 harness but I would need to splice some wires to get everything to hook up. My question is. Which wires am I going to have to spice. My accord was already vtec to I shouldn’t have to do anything for that for that correct? What else am I going to have to change besides trying to find a conversion for the iacv from 3 pi to 2 pin? I live in Florida so is it necessary? I bought a stage 3 clutch 6 puck 11.4 lb flywheel to replace the one in the car. I purchased so obd1 to obd2 injector wires as well as obd1 to obd2 distributor wires. Are the going to work? I am going to harbor freight to purchase a engine hoist to put the motor in within a few days. I would really appreciate all the help I can get. I don’t have time or money to be having a mechanic work on my car so I am doing it myself. I am not dumb and I’m sue I can get it done with a little help. So if your are reading this and have any advice, I will really appreciate it.
Old Sep 23, 2019 | 09:49 AM
DaIll1's Avatar
Default Re: Swapping a F20b into my manual 94 accord. Please help!!!
This may help
https://honda-tech.com/forums/hybrid.../#post28490807
Old Sep 24, 2019 | 06:08 AM
Originally Posted by DaIll1
thanks for the link.
Old Oct 25, 2019 | 06:49 AM
Ok so I have everything ready to go and about to drop the motor into the car. My only issue now is that I need to find out which wires and plugs am I going to need to splice to get the F20b to run with the F22b harness.??? I have the conversion harness for the distributor as well and the injectors. What else do I need to do? Thanks in advance.
I have been looking all over on forums and everyone only said you are going to need to do some splicing but they don’t say where and what...
94accordf20b
Sep 22, 2019 08:44 PM
coreysimpson86
May 25, 2013 01:31 PM
anonymus913
May 14, 2009 10:16 AM
2nrz
Jan 21, 2008 08:11 PM
