I purchased a F20b for 531$ with a 90 day warranty. It came with the engine wire harness and ecu. I pulled out my f22b1 from my accord and planning on reusing the f22b1 transmission until I can afford a better transmission. The motor mounts that were on the car originally were shot so I ordered new motor mounts. The axles are ok. My issue is the wire harness for the motor. I have read that I can reuse the f22b1 harness but I would need to splice some wires to get everything to hook up. My question is. Which wires am I going to have to spice. My accord was already vtec to I shouldn’t have to do anything for that for that correct? What else am I going to have to change besides trying to find a conversion for the iacv from 3 pi to 2 pin? I live in Florida so is it necessary? I bought a stage 3 clutch 6 puck 11.4 lb flywheel to replace the one in the car. I purchased so obd1 to obd2 injector wires as well as obd1 to obd2 distributor wires. Are the going to work? I am going to harbor freight to purchase a engine hoist to put the motor in within a few days. I would really appreciate all the help I can get. I don’t have time or money to be having a mechanic work on my car so I am doing it myself. I am not dumb and I’m sue I can get it done with a little help. So if your are reading this and have any advice, I will really appreciate it.
Reason: Delete
