Gasket/Seal Name (99 Civc EX Auto Transmission)
Old Sep 17, 2019 | 08:36 AM
guapo686's Avatar
Icon7 Gasket/Seal Name (99 Civc EX Auto Transmission)
Hello I have a leak between the transmission and the engine and I am trying to track down the gasket/seal name to order the part. Would it happen to be the rear main seal? Any help with this would be greatly appreciated.
thank you.
Old Sep 17, 2019 | 11:05 AM
tony_2018's Avatar
Fish Twig
Default Re: Gasket/Seal Name (99 Civc EX Auto Transmission)
whats leaking?
Old Sep 17, 2019 | 08:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If your rear main is leaking (oil) then Honda calls it a Crank Seal (Rear). If your Input Shaft Seal is leaking (transmission fluid) then it's Input Shaft Seal.
Are you sure the leak is inside the bell housing area of the engine/tranny and not coming from somewhere else?
Old Sep 18, 2019 | 05:01 AM
NVturbo's Avatar
O.G. triple O.G.
from on top -
VTEC solenoid gasket
distributor o-ring
valve cover gasket
at the clutch/tranny dust cover (bottom) -
rear main seal
Old Sep 18, 2019 | 06:12 AM
guapo686's Avatar
Perfect. I just wanted to confirm it was the rear main seal. Thank you so much.
Old Sep 18, 2019 | 06:42 AM
tony_2018's Avatar
Fish Twig
Yeah but you didn't confirm what was leaking, transmission fluid or oil? So it could be either the rear main seal or the seal on the shaft of the transmission.
Old Sep 18, 2019 | 06:46 AM
guapo686's Avatar
Honestly not sure. Brother in law is working on it and didn't take pics so I'm having to kinda research/guess what he was talking about since he will be doing the work. If you have the name of the gasket/seal for that shaft I will buy that part as well as parts are quite cheap.
Old Sep 18, 2019 | 08:37 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Input Shaft Seal (Transmission)
Rear Crank Seal (Engine)
Fitz Williams
Jun 28, 2018 01:06 PM
beastyben1
Honda Civic (2001 - 2005)
Apr 6, 2012 12:16 PM
Civic082382
Oct 4, 2010 06:22 PM
shortlid
Oct 22, 2007 06:45 PM
HYREV2NR
Aug 16, 2004 01:13 PM
