B16B max bore with original sleeves
Old Sep 17, 2019 | 03:52 AM
Risto's Avatar
Default B16B max bore with original sleeves
Hello! Does someone know what is the max diameter what you can safely go with B16B block with original sleeves NA engine? ( Block P72 same as ITR ). Thanks!!!
Old Sep 17, 2019 | 06:06 AM
BiggieBert's Avatar
Loved
Community Favorite
Default Re: B16B max bore with original sleeves
Just speculation, but I would venture to say 84mm
Old Sep 17, 2019 | 08:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If you intend to stay Naturally Aspirated, you can safely go as high as 82mm... although MOST people will recommend going no larger than 81.50mm. You will have an easier time finding pistons in the 81.25 and 81.50mm sizes.
This suggestion would have destroyed the block.
Old Sep 18, 2019 | 04:59 AM
BiggieBert's Avatar
Loved
Community Favorite
Hence why I didn’t present it as fact.
Old Sep 18, 2019 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Absolutely... and this is why I framed it as a "suggestion" instead of "fact" as well. No animus intended.
Old Sep 18, 2019 | 09:49 PM
Risto's Avatar
Thank you JRCivic1 and BiggieBert!!!
92VXeg
Nov 21, 2008 10:28 AM
RTW DC2R
Feb 20, 2006 11:20 AM
hbvetteslayer
Jun 26, 2003 08:56 PM
satan_srv
Mar 19, 2003 01:52 PM
