Help with 5 to 4 wire o2 conversion
Hey all,
I am doing an 1999 b18b1 into my 1992 civic vx. I am using and obd1 ecu so that I only need 1 o2 sensor however, I am using the ls harness. I've searched for threads that show how to re-pin the ECU when using the vx harness on the motor however I am using the ls harness. So just to clarify you DO have to change wires on the ECU even when using a 4 wire harness correct? If so which wires?
Thanks
Thanks
90AccordVTEC
Oct 12, 2005 05:24 PM
PhatwhipsJDMkits
10
Nov 11, 2004 06:38 AM
