K swap cost?
Hi
RecentlyI fuckup my D16Z6 on my Ej1 and I was thinking about a K swap. A friend told me it would cost around 7k - 8k but I think it would be done for more less than that. How much does a K swap cost right now?
Cheap but good, keeping a Good balance.
Or what do you guys recomend doing with my D engine?
It has a toast rod.
It has a toast rod.
the engine/tranny can be had for under $2K. Add the cost of K-Pro ecu, wiring harness, motor mounts, axles, and other miscellaneous parts, it can be pricey. Less if you know how to wrench. If that's not the case, better pay up to have a shop or reputable person do the work.
Hi
It has a toast rod.
It has a toast rod.
Now if NVTurbo is suggesting you can get a K20A2/Z1/Z3 and a 6-speed transmission from a reputable vendor for $2000, I need his connection. Stolen parts on Craig's List or FB... maybe. Or, maybe he is suggesting a 160 HP "K" and a less desirable 5-speed trans for $2000... and that makes more sense. But WHY ??? A GSR swap will make more power stock and will be less money and easier to install.
who ever is doing the work should be able to give you an exact, you'll need to remember that you're going to run in to additional issues that require additional funds
Also, if you want to keep A/C or P/S and/or upgrade other items like a clutch, cat-back exhaust or freshen-up parts like the timing chain, tensioner and guides... the price will go up as well.
Unless you find a crazy deal on a wrecked RSX or something, your prices will be very near what these fellows have said.
Like I was told by a particular company that is intimately familiar with these swaps, the key is finding a good donor vehicle.
This is true... but with the savings comes additional labor in removing the engine/trans/wiring/ECU etc. and the logistics of storing another car in your driveway while this process transpires (My HOA wouldn't allow this level of mechanical work in my driveway) as well as dealing with disposing of whatever remains when you have removed your parts.
