Mishimoto Oil cooler Install issue
Old Sep 5, 2019 | 11:53 AM
piggy96's Avatar
Default Mishimoto Oil cooler Install issue
Sorry if this is on the wrong forum but figured it would be the most likely spot someone may have an answer.
The problem I’m having is installing the sandwich adapter to the block. I don’t have the oem oil cooler and the fittings on the top of the adapter hit the coolant tube making it impossible to mate the adapter to the block. I’ve tried spinning it in any direction with no luck. Has anyone had this issue?
The only thing I can think of is adding my greddy adapter to space it out, just concerned if this would cause any other problems, or would I have to try and source the oem oil cooler?
This is is on a b18c block
Without greddy adapter
With greddy adapter
Old Sep 6, 2019 | 08:15 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Mishimoto Oil cooler Install issue
different AN fitting perhaps?
Old Sep 6, 2019 | 08:30 AM
maxwellmercer's Avatar
Not a bad idea, a 45 or 90 degree fitting MAY clear in the upward position.
Old Sep 6, 2019 | 11:36 AM
piggy96's Avatar
I tried both, the banjos were my last hope. The issue I think is the Mishimoto adapter is taller than the others making it just about impossible.
Old Sep 6, 2019 | 04:50 PM
Ericjergs's Avatar
Has anyone experienced this issue on the d16? Was thinking about going mishimoto.
Old Sep 6, 2019 | 09:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
OP, what about rotating (tightening) the banjo bolts so that a flat side is facing the water pipe instead of a corner as you have pictured above ???
Old Sep 6, 2019 | 09:41 PM
piggy96's Avatar
Good point. Theres still about a half inch gap between the adapter and the block after trying. I can try getting some better pics. As of right now I think using the greddy adapter as a spacer may be my only option until I find the oem oil cooler.
itr1244
Jun 3, 2007 10:26 AM
bosco500
Apr 4, 2005 03:15 PM
mugenracer
Aug 8, 2002 10:38 PM
