1994 Civic LX, blown head gasket, what to do next?
Hi forums!
Back in February, I bought a one owner, completely stock, 1994 Civic LX sedan in good condition with a book of maintenance and repair records going all the way back to 2001 for $1500. Despite some minor issues (glitchy intermittent wipers, power steering fluid leaks, no AC) the car has had zero issues in the 4,000 miles I've driven since I bought it, but about 3 weeks ago the temperature started creeping up when idling in heavy traffic for more than a minute or so. When I turned the heater on it would go right back down to halfway so I didn't think much of it.
Last Monday, I was sitting for about 3 minutes in a congested intersection trying to turn left when I looked down and noticed my temperature was pegged in the red. I freaked out and did a U turn, swung into a parking lot, and noticed that the temp had gone back down to about 3/4ths of the way up, but I turned the car off immediately. Hearing horror stories about aluminum heads warping and blowing head gaskets from just overheating the engine once, I decided not to risk driving it any further and had it towed to a nearby well-established mechanic over the labor day weekend.
I got a call from the mechanic on Tuesday morning, stating that they did a pressure test on my cooling system and the test revealed that the engine had a blown head gasket. I reluctantly asked him how much they'd charge for a head gasket replacement, and he said that it would be a waste of money since "the bottom end of the engine is very weak" and putting a new head gasket in would put too much stress on the other parts of the engine, and that I would be better off with either a new engine or a new car. I was devastated and just told him that I'd have it towed back to my house after I got off work, and it's been sitting in my driveway since then.
Now that I've had some time to think about it, what are my options now? I don't want to sell the car, since it's my first car and I saved up for months to buy it. Where should I look for a replacement engine? Or should I try replacing the head gasket myself? I feel like they were just trying to get rid of me by dismissing all of my questions with "nope, you just need a new car." The engine is a D15B7 with 232,000 miles on it.
hmotors seems to be the go-to guys:
https://www.hmotorsonline.com/
just wondering how they know the bottom is weak.
honda brand head gasket should be about $65.
you'll need new head bolts (can't be re-used) for $40
or so or arp head studs ($130) which can be re-used.
timing belt/tensioner/water pump should be done while in there,
that's another $80 plus any tools you don't have.
here's a good parts guide:
https://honda-tech.com/forums/honda-...civic-3114911/
make sure the block and head mating surfaces are clean as hell
and look at some youtube vids to get the hang of it.
Your mechanic says the D15B7 is too weak to put in a new head gasket after having the head resurfaced for flatness? I find that a little ridiculous but to each their own.
If you are after power then I get it. But if you are after a decent economy car, that's exactly what the LX D15B7 motor is about.
A new head gasket would not stress other parts of the engine, that was a pure cop out in my opinion. I think he used the cop out as in his mind the amount of money to pay someone to do the head gasket job is better spent on a more powerful, less economical motor. For just a little bit more, b series blah blah blah.
What do you want from the car? That is really the question.
Its just a precaution but they should've been honest, they are concern that if they do the headgasket more issues might arise.
Saratoga11
May 22, 2017 02:25 PM
shm91
33
Oct 10, 2013 09:30 PM
