Ebay Universal keyless entry
Has anyone installed this on their car? I'm having some trouble finding the best way to get this to work, my driver side door lock doesn't turn so wanted to go keyless. I removed the lock cylinder and basically have the actuator bolted to the door handle bracket, protector. I'm almost there just that the actuator is not pushing the rod enough with the current setup.
Or could I get some oem style actuators and just use the keyless brain to control them?
I have a VP coupe
I have a VP coupe
So I answered my own question, went to the junkyard grabbed a lock actuator and connector and connected to the eBay brain. Works perfectly.
I also used sedan rear handles to remove the lock, have to use the rear handle bracket from the sedan to make it work.
h22HatchEG
Feb 23, 2006 08:42 PM
