Suspension & Brakes Theory, alignment, spring rates....
Will 93 integra suspension parts fit a 98 civic hatch?
Old Sep 3, 2019 | 04:47 PM
Boostedek98's Avatar
Default Will 93 integra suspension parts fit a 98 civic hatch?
I have a bare bone shell of a 98 hatchback and a da with rotted body. will the suspension front and rear bolt up to my ek? (struts, control arms, sway bar etc.) its just so I can have it rolling and move it around temporarily in my shop when needed. And if I should be asking somewhere else, please let me know!
Old Sep 3, 2019 | 08:31 PM
Tyson's Avatar
Default Re: Will 93 integra suspension parts fit a 98 civic hatch?
It'll work but not ideal in suspension travel. You'll need later front forks and a some washers to fit the rear lower control arm bushing as that's different width.
I would not bother.
Old Sep 5, 2019 | 11:12 PM
KiNGDEE206's Avatar
Only the front and rear coilovers/ strut-spring will work
the camber kits and the sway bar will not work
front u must use complete shock spring / coilovers setup aka
front fork shock over to your 96-00
Ef da front shocks are smaller in diameter than the newer gen
rear will plug and play. Just go buy random medium size washers to fill the gap
your rear Ef da eg dc db shock diameter where the lca foes between is about 2”
while 96-00 chassis is 1.75”. When u put rear shocks onto your ek lca. You have a gap of .25” ao washers to fill the gap
HybridKOOP
Northeast (Sales)
Aug 28, 2006 07:31 AM
WHORE: JDMCoveralls
14
Feb 27, 2006 08:55 PM
WHORE: JDMCoveralls
Suspension & Brakes
Feb 20, 2006 07:37 PM
mckenzie
Northern California (Sales)
Sep 14, 2005 06:48 PM
tmg
Jun 3, 2002 02:36 PM
