2009 Honda Accord - Airbag Light on - Video - Please Help me find the Code
Hello all!
I have a 2009 Honda Accord with the Airbag Light on. I have a wire in the plug at the #4 and #9 position of the OBD2 plug.
Please Please Help me find the code. I see 4 -5-4 but I'm not sure
Here is the video with the code output via the airbag light
Thanks for your help!
Hello all!
https://youtu.be/FOsmaHYCdUA
Something seems off about the airbag light. Its flashing too fast in some instances.
Honestly youre better off with an OBD 2 code reader....
As far as I can tell, you can't read the Airbag/SRS code with a regular OBD2 code reader. You need a more advanced code reader. If I'm wrong, please point me to a good Airbag code reader around or under $100
See this thread for the Complete SRS code list https://honda-tech.com/forums/tech-m...-list-3111979/
Last edited by jetskirentalmd; Sep 3, 2019 at 11:09 AM. Reason: correct spelling of word "thread"
No reason to apologize. We are all here to learn from each other's experience and share knowledge.
I looked up the diagnostic procedure for SRS codes for your vehicle and no where does it state to short Pin 4 to Pin 9 to pull SRS codes. That procedure may be for an older or different model Honda.
If you wanna pull the SRS codes youre gonna need a code reader. I suggest Amazon. You may not find one for under $100 but I saw a few capable readers for under $150:
YunkerHonda
Honda Accord 2016- 2017
Jan 22, 2018 03:49 PM
Sergey.R
Jul 24, 2017 02:04 PM
