sandy f22b2 94 accord lx auto trans f22b2 sandy
Old Aug 31, 2019 | 09:35 AM
Cdplayer22's Avatar
Icon4 F22b2 Crank No Start
the day i bought her
this all the sand that was trapped under the fender -___-u can see y I wanted to power wash her
I bought the car for 350.00$....when i bought it the car }}}}RAN&DROVE{{{{.... it was my daily.....I came to discover that the engine bay was riddled with SAND!!!!!!!! I have pics and video if need to prove that the car RAN&DROVE....any who I wanted to power wash the BAY to remove SAND..without dropping the engine......SOOOOO I removed parts that I didn't want water any where near distributor+ignition coil///intake manifold////power steering////alternator////and resistor box.....I wrapped all electrical connectors in plastic and ponds of tape I have pics and vid if need.....all was{ DRY DRY}….after removing pounds of tape...... I reinstall all parts that I took out.... I GO TO START the car and get nothing but strong cranks.....battery is charged...….so I bought{{ BRNAD NEW}}Dizzy Cap+ Rotor///Spark Plugs+Wires NGK'S....weeks laterI bought PARTS FROM PULL A PART aka Junk yard !!!!!!!yesterday!!!!!!! {{I bought Junk Yard}}Distributor An Ignition Coil and I swapped}}} the ecu {{{from one of my old accords it was a f22b2 as well....after doing all of that thinking it might help NOTHING worked...…..
don't think im getting spark {{I tried{{ pulling a spark plugs and putting test light straight to battery ground NO SPARK -__-
not getting my normal buzz from fuel pump....I ran 12v's straight from the battery to the pump I get the BUZZ Then.....}} I tried {{the 12vs to the pump and trying to start it still NOTHING!!!...…. }} I tried {{ starter fluid straight to the intake I got one SAMLL PUTT!! and mean one lolz......there was an old alarm system under the steering column I removed it and the car still ran and turn on !!!!after!!! removing the alarm system I don't think it had ANYTHING TO DO WITH IT NOT STARTING....I checked the starter signal FUSE with a test light and it barley lights up the test light I mean a faint light only on one side of the fuse...but if I use a paper clip and and jump the starter signal fuse it cranks the car....the car has me baffled at this point yes im getting good ground when I check the fuses from under the hood and foot panel work fine...only fuse giving me issues is STARTER SIGNAL ill do any thing to get my daily back it the only way I get to work been barrowing my moms car HELPPP
Old May 29, 2021 | 05:57 PM
Cdplayer22's Avatar
Default Re: sandy f22b2 94 accord lx auto trans f22b2 sandy
bump
Old May 31, 2021 | 08:35 AM
Jeremy64's Avatar
Originally Posted by Cdplayer22
bump
it sounds like you need to go back and double check alll of your work and do it thoroughly.
dont forget grounds are just as important as supply wires, battery and connectors.
Maybe also check your main relay, i do not think it is the issue if it ran and drove before hand.
check your battery
Anthony Liardo
21
Oct 16, 2017 10:22 PM
keico
Honda CR-V & Element
36
Jul 26, 2011 01:55 PM
ride5150
Mar 31, 2011 06:03 PM
spoonjdmeg6
Feb 28, 2009 07:21 PM
way2much
30
Aug 2, 2006 04:51 PM
