Screws broke off on thermostat housing.
Old Aug 29, 2019 | 11:31 AM
David Herzog's Avatar
Default Screws broke off on thermostat housing.
I have a 98 Civic ex and the screws broke off on the housing. Is there a way to remove the housing. I already remove 2 screws 3 hoses. Thanks
Old Aug 29, 2019 | 12:29 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Screws broke off on thermostat housing.
The housing bolts to the block with two long 10mm bolts. Remove those, then pull / wiggle the housing off the water pipe. There is an O-ring on the water pipe that seals against the inside of the housing. This may need replacing when you go to reassemble.
Old Aug 29, 2019 | 10:46 PM
oldman9's Avatar
Here's a different angle. The holes for the broken bolts go all the way so it shouldn't be too hard t get them out.
Old Aug 30, 2019 | 05:34 AM
09chaplak's Avatar
Loves Tossing Salad
I would be so pissed if that was me. If it's just bolted on Rockauto that **** and replace the whole thing, **** the screws.
Old Aug 30, 2019 | 08:15 AM
tony_2018's Avatar
Fish Twig
replace the housing, get new bolts for the housing and the neck.
T T
Feb 22, 2019 11:34 PM
tweedersgal
Honda Civic (2001 - 2005)
Apr 22, 2007 04:52 PM
coot_er
Oct 26, 2005 07:00 PM
