Please give me an idea how to remove it.
I have a Honda accord 2009. Recently there is an oil leak between the joint of the power steering return hose (OEM part number, 53734-TA0-A01) goes into the pipe under the part Honda called,
"Rear engine mount upper bracket" (OEM part number, 50685-TA0-A00). In order to replace the hose, I need to remove the rear engine mount upper bracket before getting under to reach for the joints because the hose is connecting into the pipe hide under the bracket. But I need some of you give me a good idea which way would be the best and how to remove it. It would be very appreciated and thank you very much in advance.
Sincerely,
Tony
Sincerely,
Tony
SurferX
03-03-2003 02:16 PM
