Interior lights won’t turn on
Hey so I have a 2014 odyssey and I was change the small lights on the inside and when removing one all of them just stopped working. I moved the light switch up and down, turned the car on and off, reset the battery, checked the fuse and it’s fine, but none of the lights on the interior will turn on. Has anyone had this problem from just changing the light bulb?
Again. Take a multimeter and read the voltage at the fuse. Is the fuse getting power? If it is, read it at the switch and a bulb. Check the bulb sockets for the ground. This is an electrical problem and the only way to troubleshoot is with electrical meters. No one half-world away can tell you what the problem is until you troubleshoot it and post the details.
choppyEG
Oct 12, 2013 05:36 PM
