Civic ep3 help suspension
I went full coilovers and would recommend that as well. I will say right off the bat you may run into some issues in the front from going too low with how the tie rods are set up on the ep3. Also id recommend a rear camber kit as well because you will end up with a fair amount of negative camber in the rear with a big drop.
pcapRsx
17
Feb 20, 2007 07:22 PM
RedRacer
Oct 29, 2001 04:54 PM
