B-series oil pumps interchangeable??
Old Nov 14, 2002 | 05:22 PM
neof69's Avatar
Default B-series oil pumps interchangeable??
Just wondering if all B-series oil pumps are interchangeable?? For instance if i want to run a "R" oil pump on a Gs-R Block will it work?? Are there any differences between a "R" oil pump and a Gs-R oil pump?? Thanks for the help!
Old Nov 14, 2002 | 05:25 PM
ImportReview
Guest
Posts: n/a
Default Re: B-series oil pumps interchangeable?? (neof69)
as long as they are the same year....
newer pumps don't go on well to older B series, because the cover doesn't fit on it, and they don't have the crank angle sensors..
so if you have the crank angle sensor, get a pump with the sensor...if you don't, dont
Jeff
Old Nov 15, 2002 | 01:52 PM
neof69's Avatar
Any more input on this or is Import Review's info 100% correct?
Old Nov 15, 2002 | 01:55 PM
ImportReview
Guest
Posts: n/a
Just tell me what model car, year of engine, and year of ECU and I can tell you exactly what to buy.
Thats more than enough info for me.
Jeff
Old Nov 15, 2002 | 02:03 PM
neof69's Avatar
Default Re: B-series oil pumps interchangeable?? (ImportReview)
92 Si/00 Gs-R Block/95 B16 Head/95 P30 ECU
Old Nov 15, 2002 | 02:21 PM
ImportReview
Guest
Posts: n/a
your going to need a 94/95 GSR oil pump.
End of story BOYEEEEEEEE.
Jeff
Old Nov 15, 2002 | 05:10 PM
TODAwhore's Avatar
The oil pumps are the same. The only difference is the 96+ pumps have a spot to bolt the crank sensor to.
Old Nov 15, 2002 | 06:14 PM
mugenintegra16's Avatar
Default Re: B-series oil pumps interchangeable?? (TODAwhore)
how bout the sprocket that the timing belt rides on any difference besides it has teeth for the crank sensor? and difference between b20, b18?
b20vteclsintegra
Aug 16, 2011 05:25 PM
turbosol_16
Feb 1, 2007 08:48 AM
92integraVTECgsr
Jan 22, 2007 12:36 PM
weraider30
Mar 7, 2005 05:34 PM
highcomp
Apr 7, 2004 10:45 PM
