Is it possible to get ECU codes while engine is running?
Old Aug 22, 2019 | 12:21 PM
ahtllc's Avatar
Default Is it possible to get ECU codes while engine is running?
The Check Engine Light comes on after about 20-30 minutes of driving but when I immediately try to check the code with the jumper in place, there is no code stored. Therefore I can't check the code the normal method.
Obviously, some sensor is reading out of spec but I can't tell which sensor until I can read the code. Is there any way of determining the cause of the Check Engine Light without turning off the vehicle?
The car is a 92 Civic Ex.
Old Aug 22, 2019 | 05:21 PM
muellersfan's Avatar
Default Re: Is it possible to get ECU codes while engine is running?
Yes
Old Aug 22, 2019 | 06:49 PM
tony_2018's Avatar
Fish Twig
obd1 cars yes, obd2 cars most def can.
Old Aug 23, 2019 | 11:23 PM
Hasan Khurshid's Avatar
Jump the 2 pin connector near passenger side kick panel before shutting off the car and you can read the blink sequence of the cel
jdmazm
Apr 21, 2005 07:58 PM
mprelude
Apr 18, 2005 05:32 PM
type Gendy
Apr 21, 2003 04:48 PM
