Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Acura EL Power Window Problem
Old Aug 19, 2019 | 05:02 PM
tommyt2010's Avatar
Default 2002 Acura EL Power Window Problem
I have a 2002 Acura EL. From the master switch, rear left window goes up and down as it should. But it does not work at all from the rear left switch. I first suspected the issue is the switch. But when I plug the rear right switch in to rear left connector, it does not work either. And when I plug the rear left switch in to the rear right connector, it works fine. So we can rule out the switch.
Before I start tearing apart the door, anyone have any suggestion?
Old Aug 22, 2019 | 08:12 AM
NDNV's Avatar
Default Re: 2002 Acura EL Power Window Problem
Another idea is a broken wire in the door conduit area of either the left rear door or the front driver door. Flexing of the wires over time causes them to break. I've had it happened twice and both times is was the driver's door area.
qinfujun
Jun 30, 2014 08:33 PM
einzelherz
Aug 26, 2013 06:41 AM
SurfDan5
Jan 21, 2008 05:03 PM
srswarts3
Feb 16, 2006 09:45 AM
