Rear driver side blinker not working 2000 civic ex coupe
Old Aug 19, 2019 | 04:57 PM
Dvs_sol's Avatar
Default Rear driver side blinker not working 2000 civic ex coupe
Im having this issue with the driver side rear blinker not working.. i checked the bulb and looks good i even switched it to the pass side and it work without issues.. then i figure maybe taillight harness so i switch them from driver to pass and the pass work but nothing on my driver side. So i looked under dash for the fuse and all seem to be in order. Im a bit stumped here any help would be appreciated.
Old Aug 19, 2019 | 05:33 PM
muellersfan's Avatar
Default Re: Rear driver side blinker not working 2000 civic ex coupe
Fundamental electrical diagnostics.
Use a multimeter to check for voltage and ground at the left rear turn signal socket. Which is missing?
matman4444
Jan 13, 2006 01:11 AM
Shinbo
Oct 9, 2004 09:18 PM
