Camshaft gear removal?
Old Nov 14, 2002 | 04:59 PM
kendo's Avatar
New User
Default Camshaft gear removal?
Having trouble holding the gears still to remove the bolts. End goal is to replace water pump. Strap wrench won't fit and starting to tear stuff up with screwdriver. Any suggestions on how to hold the gears without damage to anything?
Old Nov 14, 2002 | 06:25 PM
IN VTEC's Avatar
Default Re: Camshaft gear removal? (kendo)
The only way I've been able to loosen the bolt is with an impact wrench. Try to find a small electric impact if you don't have an air impact wrench.
Old Nov 14, 2002 | 06:35 PM
the DR.'s Avatar
Default Re: Camshaft gear removal? (IN VTEC)
did you try doing it with the t-belt on? i've gotten a few off like that, but most of them i just use an impact
Old Nov 15, 2002 | 12:53 PM
Kataku2K3's Avatar
Default Re: Camshaft gear removal? (CIVICtypeS)
Exactly as I do it... With the timing belt on you can normally get it loose with a quick snap of the wrench... Good luck
Old Nov 15, 2002 | 04:27 PM
kinesistech's Avatar
Why not just leave it in. There is absolutely no reason to remove the cam gear for a water pump.
Old Nov 15, 2002 | 04:32 PM
Desslok's Avatar
Default Re: Camshaft gear removal? (kinesistech)
Good point ^
Old Nov 15, 2002 | 05:01 PM
Evs-One's Avatar
Solbros Owns Me
true dat. Otherwise- impact wrench or QUICK snap of breaker bar. DO NOT stick a screw driver between cam gear and head
nighttrain33
Apr 8, 2008 06:42 PM
BB6racer
Jul 18, 2006 10:07 AM
SuperSteve737
Apr 4, 2006 03:33 PM
jaymar88
Mar 9, 2003 02:34 AM
