Ktuned HALL effect TPS, P0123 high voltage
Old Aug 19, 2019 | 04:06 AM
B_Swapped93's Avatar
Default Ktuned HALL effect TPS, P0123 high voltage
Got my 95 EG kswap running the other day, however I have one code that seems to have put the car in serious limp mode. P0123, TPS high voltage, this is the one and only code I have. TPS was scaled in kpro but I can't do anything further, I can go WOT and the car won't rev past 1800 rpm. Sensor was supposed to be brand new, I did have it and the map mixed up prior to starting which may have fried it?.
Old Aug 19, 2019 | 04:38 AM
mk378's Avatar
Default Re: Ktuned HALL effect TPS, P0123 high voltage
Yes likely to be fried. It should test out with a voltmeter the same as a regular TPS.
Won't rev up could also be because the cam timing is wrong. But resolve all codes first.
Old Aug 19, 2019 | 08:57 AM
Code went away after switching the ground and power on the plug of the tps. I'll x2 check the timing but it should say VTC phase gap if it's off or be misfiring compression is 180 180 165 180(k24a2 block)
rfm98crv
Honda CR-V & Element
Sep 2, 2013 05:08 AM
Hanmin
11
Sep 30, 2010 10:35 AM
getnasty
12
Oct 26, 2009 06:54 AM
TRYLSTEG808
May 28, 2007 07:40 PM
93sidelsolvtec
Jan 28, 2007 11:58 AM
