Will D16A6 pistons improve my compression/HP in my D15B7?
Old Nov 14, 2002 | 04:47 PM
bluedelsol's Avatar
Default Will D16A6 pistons improve my compression/HP in my D15B7?
some one offered me some A6 pistons for cheap and i want to know if they will help give me more compression or HP in my D15B7?
Old Nov 14, 2002 | 05:06 PM
yoyoperformance's Avatar
Default Re: Will D16A6 pistons improve my compression/HP in my D15B7? (bluedelsol)
i dont think so what u need is acura pistons witch are 10:1 that will take you some where i have a set if you need deal with sigle cam alot
Old Nov 14, 2002 | 05:13 PM
bluedelsol's Avatar
Default Re: Will D16A6 pistons improve my compression/HP in my D15B7? (yoyoperfomance)
i thought they wouldnt fit because the acura engine has bigger pistons, but i could be wrong, but if they fit how mutch do you want, and there is also some other stuff i am looking for, like an 88-91 crx si cam, d-series v-tech head, a civic ex intake manifold, and bigger injectors (maybe 45 or 50 plbs per hour), and a newer integar TB (like 98-up). thanks
Old Nov 14, 2002 | 05:37 PM
80 bucks with rods and all 45 lbs injectors will be too big try to find some 300 cc
injectors that should be fine for that compression
Old Nov 14, 2002 | 08:24 PM
SOHCwarrior's Avatar
Default Re: Will D16A6 pistons improve my compression/HP in my D15B7? (yoyoperformance)
d16 pistons wont fit a d15b7 because they have different rod and piston heights
http://www.heeltoeauto.com/dseries/dseries1.html
you also dont need an si cam if you get a vtec (not vetch) head
and you dont need bigger injectors unless you go trubo or ***** out na
Vtec04
May 21, 2017 08:19 AM
uo959
Sep 30, 2009 04:06 PM
My_EP3
Apr 6, 2004 06:27 PM
bluedelsol
Nov 14, 2002 06:12 PM
