2013 Honda Pilot !NEED HELP!
Old Aug 15, 2019 | 07:56 PM
Larry Hartshorn's Avatar
Default 2013 Honda Pilot !NEED HELP!
Okay so I am working on a 2013 Honda pilot 3.5 vcm motor. 67,000 miles looks to be well maintained. When you go out and start it cold it fires up beautifully and idles great. As soon as you take off from a stop you can feel a slight hesitation but it gets better after you drive a few blocks it randomly decides to turn on the stability light, vtm-4 light and the check engine light all at the same time and it begins to run on what it feels 2 cylinders. Plug in the computer and it just has random misfire codes . If you let sit for 10 minutes and fire it back up it's like it never happened with no lights on the dash until you drive it a few blocks and the cycle happens all over again. All good coil packs and new plugs. Any good advice? I'm thinking maybe vct or somthing with the vcm messing it up...the egr is clean and clear of any nasy...I'm running out of patience Thanks alot for the read and or possible advice!!
Old Aug 16, 2019 | 06:29 AM
canister's Avatar
5 Year Member
Default Re: 2013 Honda Pilot !NEED HELP!
1) battery and clamps 2) alternator 3) grounding points
67k is too early for the egr passages in the intake top plate to be blocked by carbon deposits, but everything is possible with the wonderful, beloved VCM.
Richard Cranium
Acura TL, RL & ZDX
Mar 25, 2017 02:43 AM
strykrol
Honda Civic (2001 - 2005)
Aug 19, 2014 02:55 PM
94whitecivic
Aug 29, 2013 10:13 AM
doedoe
Jul 16, 2011 11:26 PM
scotch_taped
Jul 21, 2007 09:20 AM
