Wheel bearing problem
Old Aug 14, 2019 | 10:50 AM
VizioWipe's Avatar
Default Wheel bearing problem
Yesterday I replaced the front passenger side wheel bearing and hub assembly on my 2000 civic ex, now when driving I hear a sound coming from that side of the car that only gets louder with speed, it sounds as if some metal is rubbing or wobbling but I cant figure out what it could be, as I said it only gets louder with speed, and occasionally it will stop or quiet down for a few seconds and then pick back up, the noise starts once I get rolling but when the car is stopped its silent, any suggestions or ideas?
Old Aug 14, 2019 | 11:07 AM
tony_2018's Avatar
Fish Twig
Default Re: Wheel bearing problem
how did you replace the bearing? Its important that the bearing goes wit equal pressure applied and that the hub gets pressed in with something supporting the inner part of the bearing.
Old Aug 14, 2019 | 11:58 AM
VizioWipe's Avatar
Truthfully I only had a broad idea of how to replace the bearing and hub which resulted in the noise I'm sure, I used a bearing press kit and with a socket wrench I pressed the bearing onto the car instead of the hub itself, after I tried to hammer the hub into the bearing but I was unsuccessful, the hub came off and with it the outer race of the new bearing, my neighbor walked over and offered to help by using a metal punch and hammer to push the outer race onto the new hub, then we hammered the hub into the bearing on the car, we got it fitted well it seemed and I couldn't feel any play in the new hub
Old Aug 14, 2019 | 05:21 PM
tony_2018's Avatar
Fish Twig
Oh no...big mistake on hammering the hub into the bearing..You probably fucked it up. The inner race needs to be supported or else...
Old Aug 15, 2019 | 05:28 AM
BiggieBert's Avatar
Loved
Community Favorite
Agreed, you f’d that new bearing.
Old Aug 15, 2019 | 08:35 AM
tony_2018's Avatar
Fish Twig
yeah, bearing fucked by ****** by bfh
Old Aug 15, 2019 | 08:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This shows the method without a hydraulic press:
MadVladCivic
23
Oct 13, 2014 10:46 AM
EyePhoto
11
Sep 19, 2013 02:21 PM
new_climber
13
Jun 5, 2011 08:10 AM
EX-T
15
Sep 12, 2008 06:53 AM
Bnjmn
Sep 20, 2005 03:43 PM
