VSS: speedometer inoperative + high reference voltage
Old Aug 12, 2019 | 08:47 AM
Speedr1's Avatar
Default VSS: speedometer inoperative + high reference voltage
Hello,
I have a 97 Integra LS with a GSR swap. Post swap my speedometer pointer started jumping around the scale and now does not work at all. At first I thought it was a VSS and I have a couple good ones,. So I just swapped it out. No improvement. Tach and all other gauges work.
Then I checked the VSS harness and am getting a high voltage reading on the reference wire.
Ground: good continuity
Signal:~ 12v
Reference : 9V (should be 5V).
I've looked at the harness itself and cannot see any specific areas of the VSS wires causing this issue. Tried 2 ECUs, and same issue.
Any insight on what I should track down next? Is there a shared circuit somewhere?
Thanks in advance.
t_can
17
Feb 1, 2018 04:58 PM
Steve LeB
May 3, 2012 12:04 PM
gtstwincam
Apr 13, 2010 03:51 AM
lmgsr
Nov 6, 2008 02:30 PM
NobodysHero
Jun 3, 2005 01:09 PM
