AWD Conversion Forum This forum is to help with the recent advent of new AWD conversions. Got a question? Ask it here. Got an answer? Drop the knowledge here
Can you use a different rear diff to get rid off the viscous coupler?
Old Aug 6, 2019 | 07:45 AM
01-0720's Avatar
Default Can you use a different rear diff to get rid off the viscous coupler?
Would it be possible to use say a evo or a sti or even a s2k rear diff with the honda awd trans to get rid of the viscous coupler? And have a full time awd like in evo's and sti's ?
Old Aug 6, 2019 | 02:46 PM
Chance EG's Avatar
Default Re: Can you use a different rear diff to get rid off the viscous coupler?
Part of the problem is you need a rear diff with a gear ratio that matches the transmission up front. So that makes mix-matching differentials from other manufacturers much more of a problem.
There's a lot more to it than that, I'm curious what others with more experience will have to add.
Old Aug 7, 2019 | 08:18 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I like my viscous coupler. No issues with it yet, locks up quick and it smooth with out any sort of binding that I had when I had crv trans, crv driveshaft and wagon diff
Old Aug 8, 2019 | 03:24 AM
scottcraft's Avatar
10 Year Member
Loved
Community Favorite
I think all those guys running in the 7's are using viscous couplers so that's probably the way to go.
Old Aug 9, 2019 | 11:50 PM
OD's Avatar
OD
jaguar 3.0 v6 x type & bmw 120d are the only other ones i can think of with a ratio the same (or close enough?) to work
Old Aug 12, 2019 | 01:41 PM
Ryanthegreat1's Avatar
Only the EF Wagons had a viscous coupler. The CR-Vs and Element are all dual pump.
You have to have some slip in the system or it binds. Plus the under steer would be horrendous.
Binding leads to parts wearing very quickly or breaking.
Old Aug 27, 2019 | 01:04 PM
jarrettp's Avatar
Yeah you need some way to slip. All 4 wheels rotate and different speeds in corner but with no VC you'd have one front wheel and one rear wheel trying to move at the same speed. Try putting a 4WD truck with no center diff in 4x4 and making a sharp turn on pavement. It'll buck and chirp worse than a welded diff.
Old Nov 5, 2019 | 07:44 AM
Waski's Avatar
Is it possible to use rear diff from k20/k24 CR-V for B18 with CR-V B20 gearbox?
Old Nov 18, 2019 | 07:12 PM
tigArex's Avatar
Interested in this as well.
Old Nov 24, 2019 | 12:29 PM
1Fastboy's Avatar
Dare I say Billet Diff. Can the carrier be duplicated? why re-invent the wheel just make it better.
Old Nov 24, 2019 | 12:30 PM
1Fastboy's Avatar
hmmmmm... this is a good question..
LSintegra
Honda Motorcycles
Apr 24, 2008 09:39 AM
utensil
Honda Motorcycles
47
May 16, 2006 09:47 PM
Touch
Jun 27, 2005 01:40 PM
noob with an RS
Audio / Security / Video
15
Dec 31, 2004 02:33 PM
MilanoRex
10
Mar 9, 2002 11:44 PM
