98 ek coupe rear toe bolt seized
Hey what's up guys so I working on doing a rear disc brake swap on my 98 ek and as I was taking the drum set up off I ran into a problem trying get the rear toe links out. That bolt that goes into the body at the opposite end of where the toe link and the trailing arm meet is just stuck in the body and I'm not sure on what to do or if any body else as ran into this problem and if so any ideas on what I should do to get it out. I thought about just cutting the bolt but if I do that I'm not sure on what to do as getting a new 1 in since there's no where to get to the I side nut any help is much appreciated thanks in advance
justanotherEK
Mar 10, 2013 07:04 PM
getnasty
Mar 7, 2005 05:28 PM
