Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2012 Honda Accord rear brake Noise (changed brakes, rotors are good and bearings good
Old Jul 29, 2019 | 08:10 AM
SexyTruckDriver's Avatar
Default 2012 Honda Accord rear brake Noise (changed brakes, rotors are good and bearings good
Hello all, I'm seriously stumped with why my rear brakes keep making a constant noise when I drive. The noise is constant in the sense that it occurs only when it hits a certain spot in the wheel rotation. When I took off wheel and spun the rotors the calipers seem to be pushing against the brakes to hard in certain spots and kinda grinds against the rotors. Also if it helps, the calipers are hard to take off because they are so pressed against the brakes. I changed the brakes pads, wheel bearings are fine (no play in the wheel when raised), and rotors are fine. I had my calipers changed from a quick lube place 2 years ago. The car is a manual so it has a hand break, is it possibly tighten to much? I'm really not sure why the brakes make this sound, and its quite obvious as I had people tell me about the sound from outside.
Old Aug 3, 2019 | 06:06 PM
bethaud's Avatar
Default Re: 2012 Honda Accord rear brake Noise (changed brakes, rotors are good and bearings
I have a 2005 Acura TL that had the same thing. Happened intermittently but only when turning and at a certain speed. Didn't matter if brake was applied or not. I was told there was some rust which needed to be scraped off. That took care of it for me.
Old Aug 4, 2019 | 11:13 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check to see if the caliper slide pins were properly greased.
Old Aug 6, 2019 | 01:22 PM
canister's Avatar
5 Year Member
Check that e-brake is properly adjusted.
sk8shorty012
15
Apr 11, 2011 09:04 AM
Hatchd
Aug 10, 2006 09:30 AM
potatostix
Oct 26, 2005 05:54 AM
WiLLMaTiX
Jul 20, 2004 10:33 PM
joel
Feb 4, 2002 05:54 PM
