Needing help, 1000 rpm idle
Old Jul 28, 2019 | 10:25 AM
pimpgixxer04's Avatar
Default Needing help, 1000 rpm idle
Ok guys, so my new to me engine is pulling 1000 rpm all the time. I've tried doing the idle relearn process, replaced the iacv (had p505 code) and i cannot get it under 1000. I cleaned the idle screw, didnt help. Its adjusted all the way to the right and wont go any lower. Any suggestions would be great. Also not sure if this is related, but while driving everything is fine. As soon as i come to a light with my a/c on (its hotter than **** in az) my idle drops to around 2-300.... Related? Probably but not sure.
Old Jul 28, 2019 | 10:39 AM
Default Re: Needing help, 1000 rpm idle
Oh also checked timing and its good
Old Jul 28, 2019 | 07:49 PM
Ttt
Old Jul 28, 2019 | 08:46 PM
cp_auto12's Avatar
How are your fuel injectors? I know bad ones can inject more or less
Old Jul 28, 2019 | 08:58 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Old Jul 29, 2019 | 11:03 AM
muellersfan's Avatar
Clean the IACV and then adjust the idle speed using the procedure detailed in the service manual.
Regarding the A/C, check whether the condenser fan runs when the A/C is on. It should be running.
Old Jul 29, 2019 | 12:15 PM
Injectors seem to be ok and running evenly per my snap on scanner.
Old Jul 29, 2019 | 12:16 PM
I just installed a new iacv, idle is fine when a/c is off its around 800, but as soon as i turn the a/c on it drops bad. A/c fan is coming on, both fans run with the a/c on.
Old Jul 29, 2019 | 12:45 PM
Did the A/C work perfectly until recently?
Old Jul 29, 2019 | 11:32 PM
The motor was swapped. Didnt do this before
Old Jul 30, 2019 | 01:20 PM
Did you recharge system with refrigerant?
Hook up a manifold gauge set. Measure low and high side pressures with the A/C ON and A/C running on max cool in the shade. Also post the ambient temp when test was done.
Old Jul 30, 2019 | 03:29 PM
So i did this today, this morning actually. Both gauges read good. It was 89* im sorry i dont remember the numbers, but an a/c guy at my work said it was ok. So ill take his word for it being as knowledgeable as he is. I wish he could help me with my car but he said he knows nothing about hondas and their weird quirks. But i cannot find a vacuum leak or coolant leak anywhere. Drove my car to lunch today and got a p505 code, but I just replaced the iacv last week.
Old Sep 1, 2019 | 05:48 PM
Bump, I still cannot get my car loaded (even after idle procedure in the manual) to idle under 1000 rpm. When I unplug the iacv the car stays idle at 1000 rpm. Per the manual it says after unplugging the iacv the engine may stall. Unfortunately nothing changes. And it's a new iacv. Any other suggestions?
Old Sep 1, 2019 | 07:25 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Do you have an FITV? If so, plug the hole in the throttle body with your finger and see if it changes the idle. If so, your FITV is stuck open.
Old Sep 1, 2019 | 07:39 PM
I dont think so. I have a d16y8
Old Sep 1, 2019 | 10:03 PM
K20.ek's Avatar
Distributor advanced....
Old Sep 1, 2019 | 10:38 PM
See, I thought that maybe too. Nope. It's right on the middle line (the red one) this cars being junk but I know I can get her right
Kid-jdm-teggy
May 13, 2013 12:06 PM
JSR
May 17, 2006 10:27 PM
manyakiexpi
Feb 18, 2006 11:45 AM
EK Josh
29
Apr 11, 2005 11:05 AM
