key wont turn!! HELP
Old Jul 26, 2019 | 03:56 PM
98exmigz's Avatar
Default key wont turn!! HELP
when ever I insert the key and press the clutch down to turn it, it wont turn. anyone else have this issue? what do I need to fix it or what part do I need to buy?
Old Jul 27, 2019 | 04:23 AM
muellersfan's Avatar
Default Re: key wont turn!! HELP
You may just need to have a new key made.
Old Jul 27, 2019 | 07:35 AM
saywhat's Avatar
Or try slightly turning the wheel to relieve the pressure of the ignition column lock?
Old Jul 27, 2019 | 09:08 AM
98exmigz's Avatar
I've tried moving the wheel but it's not locked, I literally have to mess with the key wiggling it for a couple minutes till it turns.
Old Jul 27, 2019 | 09:46 AM
Clean the ignition switch lock mechanism with WD40 and also make a new key. Then go from there.
Old Jul 27, 2019 | 11:46 AM
mk378's Avatar
Are you saying you can't physically turn the key to the starting position III, or that when you do turn the key to III nothing happens?
Old Jul 27, 2019 | 08:39 PM
98exmigz's Avatar
the key wouldn't turn to any of the positions(1,2,or3) I ended up buying the switch lock at O'Reilly... quick 20 dollar fix. turns like a charm now 🙌
Old Jul 28, 2019 | 04:30 PM
tony_2018's Avatar
Fish Twig
these cars are getting old so the cylinders could get worned out. I would've rekeyed all the cylinders in the car to be safe.
dreaducky
Honda Civic (2006 - 2015)
Aug 10, 2013 07:08 AM
Armando Galvan
Nov 2, 2012 02:38 PM
1sikhatch
Apr 9, 2010 08:41 AM
fkguitar
Aug 6, 2005 10:03 AM
