Assistance needed: Testing ignition system for spark
Old Jul 18, 2019 | 07:46 PM
spoonhbk11's Avatar
Default Assistance needed: Testing ignition system for spark
I am getting no spark at distributor and have replaced it with used one as well as new coil and igniter but no luck besides only a couple times vehicle started (after coil replacement/prior to tow) but eventually wouldn’t start after several diagnostic tests (tests pass) via test light at distributor igniter/coil. As a result code for ignition output appears and have found out that test light will light up when connected to negative terminal for igniter/coil with out vehicle power on and won’t pulse upon cranking. (Test light connected to positive side and not negative for test - [didn’t pass]). Any suggestions as to reason of results since not sure what to inspect.
Old Jul 19, 2019 | 06:33 AM
spoonhbk11's Avatar
Default re: Assistance needed: Testing ignition system for spark
TheShodan
Old Jul 19, 2019 | 06:39 AM
spoonhbk11's Avatar
at 8:09 test begins
Old Jul 19, 2019 | 01:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Scanner Danner is a really sharp ,respected guy in the automotive profession.
I'd watch the whole video and go from there.
Old Jul 19, 2019 | 03:51 PM
spoonhbk11's Avatar
I have but doesn’t explain as to reason test light lights upon contact of igniter pin test at 8:09 and doesn’t flash while cranking like should
Old Jul 19, 2019 | 06:28 PM
spoonhbk11's Avatar
Update: Ok, so just re-checked test and looks like it doesn’t light up on contact since I removed (-) wire to icm pin this time... I will try exchanging icm’s... prayers please
spoonhbk11
Engine Management and Tuning
Jul 19, 2019 06:37 AM
TPersaud
Feb 13, 2019 09:48 AM
wunfstgsr
Sep 7, 2017 09:01 AM
S.A. civic
10
Aug 18, 2013 01:19 AM
jjdickm
Mar 16, 2006 07:54 PM
