98 Accord EX 3.0L(J30A1) wiring help needed
Old Jul 17, 2019 | 09:26 AM
rchapman's Avatar
Default 98 Accord EX 3.0L(J30A1) wiring help needed
I have a few wires I need to pigtail. I am trying to find a good wiring diagram that shows connector type and terminal type. I am sure the terminal are Sumitomo 090 2.3mm male/female on most of the connections but want to be sure. Also, where can I get good auto grade wire to make my own pigtails. The connectors are all good, i just need to replace the wire on a few so I plan to reuse the connector but install new wire and terminals. Thanks much
***I have the 3.0 liter V6 J30A1 and an auto B7XA transmission
Old Jul 22, 2019 | 07:03 AM
bavarianbl3ss3d's Avatar
Default Re: 98 Accord EX 3.0L(J30A1) wiring help needed
There is a decent amount of wiring info in the Helms manual but the connector specifics you are looking for aren't there. You may have better luck contacting someone like connectorsupplier.com
to see if they can help you find the right parts. Are you trying to get the crimp connectors to fit the factory plugs after running new wire? Measuring the connectors with a digital caliper so you can provide the dimensions would help someone trying to find it for you. Also you could hit the easy button and just replace the whole harness.
cudaboy
May 31, 2016 03:04 PM
RIZOBIZERT
Feb 28, 2008 12:25 PM
JDM civic master
Audio / Security / Video
Sep 25, 2004 06:22 PM
sightless
14
Apr 27, 2004 04:43 PM
