P0401 Issues
Old Jul 8, 2019 | 09:29 AM
Brian Roche's Avatar
Default P0401 Issues
Hi, I'm new here. I was hoping someone could help me out. I got the P0401 code (EGR Insufficient Flow). I cleaned out all the ports (because that's usually the problem), and the code came back a day later. So I went ahead and replaced the valve, and it still came back a day later. I don't know what else to do. Any ideas? Thanks in advanced.
Old Jul 8, 2019 | 02:02 PM
hondaslave1342's Avatar
Default Re: P0401 Issues
Most likely your egr ports are clogged..use the search box to research more throughly ..
Old Jul 10, 2019 | 03:59 PM
MAD_MIKE's Avatar
MM Gruppe B
Which model year and which engine do you have?
F23 98-02 it's usually just the main port between the upper plenum and runners that becomes clogged.
F22 96-97 the EGR manifold is fairly easy to remove and clean out, along with the ports in the runners.
J30 98-02 the main feed port between upper and lower is usually clogged and may need to be better addressed by removing the upper plenum. Gaskets are reusable.
Old Mar 28, 2024 | 09:51 AM
MERT454's Avatar
I am having the same issue now. What fixed it?
kwilson4921
Mar 28, 2024 09:53 AM
tortis
Jul 4, 2015 10:06 PM
daitantamashii
Dec 29, 2010 12:06 PM
RaceitFixit
Sep 11, 2007 05:39 AM
lax1089
Mar 28, 2007 10:03 PM
