2007 CR-V blows warm air while idling.
I have a 2007 CR-V which blows cold air as long as the vehicle is moving. After about 10 minutes at idle, the air starts to warm up. I have checked the fan relays, and the pressures seem good.
Sounds like your heater core is not closed completely. Make sure that the valve operates as expected. If a screw is loose on the valve, the lever may not be doing anything to close the valve.
seeingidawg
May 27, 2008 10:45 PM
BauleyCivic
10
Apr 3, 2006 12:04 PM
