AC removal question?
Hello I have a 1991 honda civic hatchback, I want to use this car as a track car, and loose weight here and there. I want to remove the AC it doesn't work just blows hot air, and i want to remove it. But i am a little scared of the V12 i heard it can make you sick and vomit and stuff. So how can i tell if there is anymore in the actual system. How can i remove it legally and is there any advice you have on this job?
If it still has the cap, it will look like a big valve stem cap (for a tire) that is blue. Unscrew that, and there is a schrader valve under it (again, looks like the valve stem on a tire). Use a small flathead screwdriver to temporarily press the shrader valve - if it hisses and blows out anything, you will need to have the system evacuated by a shop. If nothing happens, the system is likely empty.
