1993 Honda Del Sol Speedometer Calibration
Old Jul 1, 2019 | 10:24 AM
Aiden-hamilton's Avatar
Default 1993 Honda Del Sol Speedometer Calibration
Hi guys my names Aiden & I own a 1993 Honda Del Sol S.
Since I bought the car my speedometer has been reading way slower than my actual speed.
My GPS says 100, my speedometer says 40 Km/h
I tried changing the vss sensor, no change. I tried swapping the cluster with a used one, no change.
I am running bigger tires. I put the original tire size on the car to see, it made no difference.
Stock = 175-70-13
Current = 205-40-17
What can I do to fix my speedometer?
Thanks let me know what I can do
Old Jul 1, 2019 | 09:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1993 Honda Del Sol Speedometer Calibration
How much slower is "way slower" ???
Old Jul 1, 2019 | 09:33 PM
Like im going 70km & it says 30km..
when i start moving, the speedo doesn’t actually start moving until about 15 km/h
Old Jul 1, 2019 | 09:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That difference is not because of the larger tire size... I suspect you have a speedometer problem. I would test this by installing a known good gauge cluster and see if the speedometer reads more accurately then.
Old Jul 2, 2019 | 03:45 AM
mk378's Avatar
Likely your new speedometer is also defective. Is the odometer close to being correct? You will lose some percent going to larger tires but not 50%.
The speedometer head is actually a rather complicated bit of electronics that is mostly digital, so there's nothing to adjust or calibrate. It does have a couple of electrolytic capacitors that will fail over time though, and often capacitor replacement is all that is needed.
Old Jul 2, 2019 | 07:14 AM
muellersfan's Avatar
Is code 17 thrown?
Old Jul 28, 2019 | 07:30 PM
No code 17.. I did some more testing. The VSS is putting out a pulsing voltage when you turn the wheel. I have continuity from the VSS sensor all the way to the speedo. I also have power and ground to the speedo.. theres only 1 thing it could be right?
Old Aug 1, 2019 | 12:31 PM
BiggieBert's Avatar
Loved
Community Favorite
This is the tachometer procedure, so if you can find the formula for the speedo, the procedure should be the same.
https://honda-tech.com/forums/honda-...epair-3336440/
Old Aug 2, 2019 | 11:49 AM
Outrun's Avatar
It seems like 90s Hondas/Acuras tend to read 5mph slower than GPS on the highway.
